Partial synchronisation
What I did: Installed Agenda on 2 MAC machines (Macbook pro 2013 and a Macbook Air 2015, both running High Sierra. I created account for Agenda and loged in on both machines. I have been creating notes on the Macbook Pro
What happened: Only two of my three projects are synchronised to the MacAir and the note I created today on the Mac Pro (under one of the synchronised projects) has not been synchronised.
What I expected: To have exactly the same content on both machines.
Things that might be helpful to know (Agenda version, OS and model, etc): Agenda Version 1.3 from App Store
Thank you for nay assistance
@drewmccormack for you
Worth seeing if quitting Agenda on each Mac, and relaunching it, gets the sync to work again. If that doesn’t work, try restarting the Macs, and launching Agenda.
And if even that doesn’t work, we have found that iCloud can sometimes get ‘stuck’, and that logging out of iCloud in System Preferences, and then logging back in again, will get it working again.
A post was split to a new topic: Partial syncing
