Overview Naming
Hi, I’m loving Agenda 20 and my issue here is a trivial one. I use the reminders integration to handle all of my ‘to-dos’ and have a smart overview for this. It works really well. I use Agenda’s checklists for broader goals etc, not for specific To Dos, so it’s a minor frustration that I can’t change the name of the ‘To Do’ overview to something else (i.e., in my case, ‘Goals’).
My advice is just to make your own “Goals” overview. It is a minor irritation that you can’t hide “To Do”. We will try to fix that in future.
To create “Goals”, search for \todo
If you want to put any other constraints on it related to reminders, include \remind
Save the overview with the buttons at the bottom.
Hope that helps!
