Hi!! I use Microsoft Outlook in my work and I would like to know ir there is any way to sync it with Agenda, for example sending the emails or the tasks, i dón’t know if with a siri shortcut is possible… Any advice?
Hi, I am use Agenda with Reminder and Microsoft Todo.
How Can you integrate it?
I am use Ipad and install app Microsoft Todo. The MS Todo sync with Reminder automatically. And app Agenda sync with Reminder too.
Hi, you can use the native app from iOS to syncronize the calendar of your work, dont use it for mails just only for calendar and then you will see all yours meeting in Agenda.
Pelayo,tengo el mismo interés, cómo lo has podido hacer?
As with any calendar provider, Outlook, Gmail, iCloud etc, you will need to configure the account in the System Preferences (macOS) and/or Settings app (iOS and iPadOS). Once the calendars and reminder lists show in the system Calendar and Reminder app, they should also become available inside Agenda.
