Option-Tab doesn’t work on iPad?
Pressed Option-Tab
Paragraph indented
Cursor to move to be able to create a ‘column’
iPad Pro, iPadOS 13, Agenda 9.1,
Not quite sure what you mean by a “column”. We don’t support tables at this moment. Do you mean a “tab” character?
We added the option of entering a tab on macOS, using option-tab, but I have a feeling we didn’t add that on iOS. Is that the problem? You miss it on iOS?
Yes, a tab character, to essentially mimic a column. I’ve replaced my Mac with iPad Pro so I use iPadOS rather than MacOs - I would definitely use / miss this functionality. Thanks.
I’ll add it to the list. I believe it is more difficult to do it on iOS, but we will investigate.
