Open in separate window without losing current view, and alphabetic sorting
Hi!
I have a couple of suggestions that would improve Agenda.
First, it would be great if it was possible to open a note or project in a separate window from the sidebar without the main window jumping to that note/project. Usually when I want something in a separate window it’s because I want to see it at the same time as the note/project I’m currently viewing. It’s annoying that the chosen note/project opens in the main view when I’m clicking it in the siderbar just to choose ”open in separate window”, so I have to open the note/project I was initially viewing again.
Second, it would be great if alphabetic sorting could be chosen as default in the sidebar.
/Anki
Hi Anki,
Thanks for the feedback! Very useful.
There are a couple of ways to do this. One way would be to navigate to the note you want to open, open it in the window, and then use the left button at the bottom of the left sidebar to go back to where you were.
Another way to do it would be to open a second window on any note you like, and click the titles at the top to change to the note or project you want.
Lastly, you can option-click on any project to open it in a separate window, and then find a note. You can also click the title at the top to get a list of the notes to jump there quickly.
Hopefully one of these helps!
We’ll take along the suggestion for alphabetic ordering of projects. We have chosen for manual ordering to give more flexibility, but we’ll see if there are others that would like this. Thanks!
