I have been using Agenda for a few days now and want to link notes to multiple calendar events. Is that possible?
Alas, you can’t link multiple events to a single note. You can link multiple notes to the same calendar events but not the other way around. If you find that your notes apply to multiple notes you might want to consider making it a project instead with a note for each event. Alternatively, you can make an “index” note that links (using Agenda links) to the individual notes tied to each event.
ok, so far so good
