-[ ] Sample
produces a check list item.
And in fact -[] also works!
But, how about even fewer keystrokes, as the dash seems superfluous anyway?
This would be cool for faster keyboarding:
[] Sample
-[ ] Sample
[] Sample
We chose that because it is already used by many web apps. Seemed better to try to stick with a convention where there is one.
Note that there is also the keyboard shortcut CMD-SHIFT-C.
Fair enough to use the convention, but you already allow
-[] as an alternative to -[ ]
So why not add [] as well? (It’s also what the web app Quip allows!)
We’ll consider it. Guess it could be an alternative.
