- Would love to have OCR search on PDF and Photos.
- Recurring Alarms
Thanks for the feedback.
OCR is applied to scans.
What is your use case for OCR? Do you want to select and copy the text, or search in the PDF?
I want to search in attached documents and photos as Everote can do.
OK, thanks.
BTW. There is a bug when I use the scan mode ! Recently I scaned 4 pages and saving re-arrenges the different pages wrong.
Do you know if it happens every time, or was there something you did that somehow caused it to rearrange?
The scan code is mostly Apple’s, so I would be a bit surprised if it did fail like that.
