Now that we have <hr>
Any way I can ask for a modification, and I don’t know if I can do myself?
When you create a note based on a meeting, it imports the attendees and the notes from the meeting. Anyway we can get an
in between the attendees and the agenda, and then another
between the agenda and the notes I am going to take for the meeting?
I think the way to do this would be to use a template to set it up how you want. See instructions here: Creating and Using Templates and Actions
Exactly as @trenso says, templates are the way to go if you like to tweak the defaults.
I figured it out. Awesome. Thanks!
