Selected a project with notes pinned to the top. Changed the View → Group Notes by → from “Ungrouped” to “Done status”
The Pinned notes to the top moved to another place, not the top.
Pinned notes should stay at the top irrespective of the grouping of the notes.
version 19.0 (302). macOS.
The pinned notes to the top might get ordered by date. So it is important to check the order on how the notes get created. Meaning, create a bunch of notes and pin an old one to the top.
This is still happening. As a workaround I have to change the date or the status of the fixed note to move it to the top but it’s inconvenient because it makes it appear on custom views.
I make fixed notes to display a summary of the project in the top along with some bookmarks.
