I use Agenda on iPad, iPhone, and Mac. I switch between all three constantly. I generally start a new note each time, because I use Agenda as a personal journal.
Sync is causing display bugs. Let’s say I write note A on Mac, then note B on iPad. When I go back to the Mac, Agenda will sync. Then note A appears empty, but the note content view is still full size. If I try to collapse the note, nothing appears to happen. If I do it again, then it redraws. A third time and it collapses properly. Sync works as expected, otherwise.
The contents of the last edited note should continue to be visible as normal.
Agenda v13 Mac App Store, macOS 10.15.7
