Note sometimes disappears
What I did: picked a project
What happened: the top-most note vanished
What I expected: to see the note
iOS 12.4
6.0.1
This image shows what happened after I tried to add a new note, but the empty spot was there before
That’s odd, do you happen to have either a lot or one or more very long notes in that project? Or does it happen in any project?
Seems to happen in any project. At first I thought it was because I attempted to turn the phone to landscape mode… but then it happened again in portrait.
Really puzzled by it, since I can’t seem to find the steps that create the problem.
The note does return if I navigate to a different project and then come back.
I think I may have discovered a way to replicate.
In a project with more than 4 notes, try creating a new one and then turning the phone to landscape. The newest note (the one you’ve just created) vanishes.
Hmm, that’s odd, thanks, we’ll try to reproduce.
I frequently find that a newly-created note seems to be missing, because it’s created at the top of the list, and Agenda doesn’t scroll to it. So, I have to scroll to the top to reveal the note.
I have seen this, too. But this behaviour is different.
Indeed a different issue. Does it make a difference how you create the new note and is this on mac or iOS or both?
I think I’ve seen it on both. I’m not exactly sure what the conditions are. I think it’s when I create a note with a date that puts it above the notes I’m currently looking at. I’ll pay more attention the next time it happens and report here.
