jmarkt
1
What I did: Selected note and attempted to highlight with specific color. (Menu>Note>Mark with Color)
What happened: Standard color selections do not apply to selected note.
What I expected: Standard color options would apply to selected note
Things that might be helpful to know (Agenda version, OS and model, etc): Custom created colors DO apply to selected note/s
We’re sorry to hear that, can you send us a series of screenshots of what you describe?
jmarkt
4
STANDARD COLOR OPTIONS DO NOT WORK
CUSTOM COLOR WORKS
That’s really weird, it works fine on my end, @drewmccormack does it for you?
jmarkt
7
SOLVED…
issue was device specific, Re-install corrected.
Thank you for the prompt reply to the question.
Great work on the app and looking forward to updates.
Really weird, it suggests that it was a preference setting that went wrong, let us know if it returns.
