Note background color problem
What I did: inadvertently changed the background color of a note and I can’t undo it. Please lhelp!
  1. Click/tap the orange dot in front of the note title.
  2. Select “Mark with Color…”
  3. Select “⨂ None” at the bottom of the color list
Thanks so much! Such a simple fix, yet I couldn’t figure it out myself.
Thanks so much! So simple! But I couldn’t figure it out myself.
Shari
The switch is usually located where it was previously activated.
I’m glad I could help you with that.
