Is there a way to change the displayed order of projects in the sidebar within a category? Simillarly is there way to change the order of notes in a project as they appear in the main window? If not, this would add a great deal of useful flexibility to the app. The majority of my notes and projects run concurrently so having them in date order (or even alphabetical order) is far from ideal especially during busy times when there are a lot of ongoing projects. It would be great if you could drag them to change the order. Or failing that, if you could put a number before the name as a way of ordering them that would work. Thanks.
Yes, since version 9.0 you can drag to reorder the projects in the sidebar, as well as the categories themselves.
These follow the same order as they appear in the sidebar.
