What I did: I wanted to save a website link to Agenda. Using safari (or youtube app), I was unable to save the link, but I could to other apps (Notes, Things)
What happened: From safari, I tapped on the share icon, a number of apps a displayed, I chose Agenda, tapped on Agenda. An Agenda window was displayed, I could select an existing note, I selected my Daily Note. Tapped Save. Nothing, no link was saved to the note.
Okay, apologies, I see what has happened. The browser does open up the Agenda window, but the section below the agenda window was hidden because I was not in a full screen display on Safari. I could not see the ‘insert’ function.
Here, the first picture shows the safari window slightly removed from the top of the iPad display. So the Agenda insert bar is hidden.
Here in the second picture, the Agenda insert bar is showing, because the safari window is set to the full height.
I see what you mean. We will try to improve this. Thank you!
We have a fix for this coming in version 22.
Thanks for reporting this.
