No insertion line when dragging and dropping inside note
I drag a list item or paragraph to change its position in the note.
When the Agenda window is on my external standard definition display (2560x1440), I don’t see the red insertion line that should show me where the dragged item will be moved to. On my MacBook’s retina display this isn’t an issue.
Show the red insertion line while dragging. This is an issue in both light and dark modes.
Version 22.3.1 (397) - Mac App Store
macOS 26.4.1 (25E253)
Thanks for the report.
Does it help if you move the drag to the right a bit to be over text?
Or is it really something with the external monitor?
I guess maybe the line is too think to appear on the standard definition monitor. Will see.
Dragging it further to the right doesn’t help unfortunately.
I took a look yesterday. I’ve repositioned the line slightly, which hopefully fixes it on lower resolution monitors.
Let me know if it doesn’t.
