When we get to the Getting started with Agenda" screen the message is “Create your first project using the orange + button at the top”.
In Mojave, the color for that button depends on the new color settings in System Preference. The button can be in fact any color that the user chose. Maybe you should use a different wording because it is very confusing when there is a green button and you’re looking for an orange one…
Thank you for your work !
