I wanted to see if I could nestle folders like on the attached pic?
Thanks! Robert
Thanks! Robert
Not entirely sure if I get what you try to achieve, you mean through the Shortcuts app?
I am asking if I can create sub folders under “Landowners”
Thanks
From a shortcut you mean, or in general?
We don’t support sub-folders in general. You can make sub-categories, or you can insert projects, but we don’t support sub-folders.
If you want a project between Landowners and Untitled (ie a sibling), that should work, but not as a subproject of Landowners.
Hope that helps!
