Is there a way to do this? Frustrated that its not possible right now, but want to shift back to Evernote after using Agenda for about a year.
Thx.
Thx.
Zip is just a general compression format, what would be the format of the files inside you would want to see?
I’m trying to reimport files today Evernote but none of the export types from Agenda seem to work?
We don’t support specifically exporting to Evernote at the moment.
