Need a way to force sync!
I made numerous changes to my Agenda notes on my phone, while my laptop and iPad were both offline. These changes do not show up on the laptop or iPad unless I make a throw-away edit on the phone on a project I want to sync. I waited several minutes, and made sure all devices were fully awake and running Agenda, before making the edits, and nothing happened. FWIW, I use iCloud.
Since this is a force-sync by another name (and a limited one at that, since it only affects the edited project), can we get a “force sync” feature in the app? Please and thank you. I get that it’s an ugly workaround for a problem that shouldn’t exist, but it does exist, and it and causes aggravation.
Because of this, I no longer trust the sync process. What if I start editing a project I updated but forgotten about on a different device? This runs the risk of inadvertent editing conflicts.
I believe that quitting the app and opening it again will initiate sync.
The app always syncs at least every couple of minutes, so you should never need to force sync.
It is possible that you making an edit just changed the order of sync. Often, it may not seem like much is happening, but there is actually data updates happening in other projects. So the sync may be going on, even if it doesn’t look like it.
Re: conflicts, Agenda is actually pretty good in this area. We made a big effort to make sure that concurrent changes would merge in a good way.
In short, I think you are just seeing a case of slow sync, or a case where it is doing a long cleanup or something. A force sync button would do nothing, because the app literally syncs every two minutes anyway. I recommend just using the app normally. You should find that it works fine if given a little bit of time to upload and download changes. (Eg if you were offline, and never took your device online, the data can never make it to any other device. Hopefully that is clear. Sync is an upload + download process.)
A startling UX omission for an app as polished as Agenda. A spinning indicator hinting at background sync activity would do worlds of good here.
There is one: if there is a long running sync going on, there should be a cloud icon that flashes. On Mac, it is top-right in the window, and on iOS it is in the right panel.
The icon doesn’t appear on every single sync, because many syncs are very short, and having it there all the time would be annoying. But if a sync is taking longer than a few seconds, it should appear and flash.
Hi @drewmccormack
I agree with @gcv about the spinner.
I did a few changes on my phone, then I had to wait like 1 min and I started to feel anxious because I didn’t see the updates on desktop. I closed the app and reopened and the updates weren’t there.
I just downloaded Notion app, and I noticed that when I type in my phone immediately it is typing in Desktop as well. I don’t know the technology that it uses, but can be awesome to have it on Agenda.
Meanwhile, if you can put a small icon to sync in a visible place to force the sync will be great.
FYI. the update that I was doing is just adding a note from template, a small change.
Agenda v14.1.1(231), Sync notes between devices: Dropbox
Note: iCloud from the beginning didn’t work for me
Thanks,
Yvonne F.
Sr QA
Notion is a web app. Your change is made in the cloud immediately. Agenda is a native app on device. The advantage of Agenda is that you always have your data with you, and can edit it anytime, even when offline for hours or days. The downside is that the sync isn’t instantaneous, because your changes are made first on the device, and will update a little later, usually within 10 seconds or so, though it can be up to a minute or so.
A button would do very little. If you simply stop typing for 5 seconds, the data should upload, and once it downloads on the other side, it will appear.
