I have started using Agenda finally as a part of my organization system and I love it. It is a beautiful app to use and I like the ease of incorporating it with my calendar which I use for time blocking. One thing I would love to see, if it is possible, since I use a bullet journal style of organizing. Is it possible to have both bullet options, the circle and dash, available at the same time? I use the circle to indicate a task or goal and the dash to indicate a note associated with the task or goal. So it would be great to have both available instead of having to choose which one is used all the time. Thanks again for all your work on this app, it’s great and I look forward to using it everyday.
Couldn’t you use the check box for goals and tasks?
Indeed what @trebso says, you could use checklists for the first, and dashes or bullets (you can change which one you’d like to use in the Agenda preferences) would be for the latter.
