I guess you mean can you choose different bullets and numbering schemes. Not yet, no. You can use indentation to get different levels, and numbers will follow their indentation, but you can’t customize the numbering yet.
Thank you for the quick reply. Yes, that’s what I mean. Or even if a single, built-in system existed, even without customisation options, would be a good start. Can I take “yet” to mean this is something you’ve been thinking about/are working on?
We aren’t working on it at the moment. It’s certainly something we could consider in future, but we have more pressing features on the list at the moment. Sorry.
I read that about Notes, and I was wondering what you meant. Seems Notes does indeed use different bullets at each level in a bullet list. In a dash list, it doesn’t. In Agenda we began with just a dash list. The bullets were added as an option later, but basically it was still a dash list, which explains why they are all the same.
Having different bullets on each level should not be difficult. Will consider it.
I’d really like the multi level numbered list, first level using 1,2,3 etc, second level using a), b), c), third level using i), ii) or something similar. Again, happy for it to not be customisable, but multi level numbered would be great. Thanlk you!
We have some nice list improvements coming in Agenda 14. Won’t include the different list markers at this point, but does give more control over numbering.
