Hi there,
is there change to create shortcut for moving note to project? e.g. things 3 has cmd + shift + m where popups window with project list with searchlike/arrowlike selecting
thank you!
Hi there,
thank you!
Not at the moment, something we’re considering to add indeed.
Update: Agenda 14 introduces actions, including the \move action that allows you to easily move a project by simply typing the command. See also : Take powerful actions using your notes with Agenda 14
I’ve just fixed it this afternoon indeed, good catch, should be fixed in the next update
