Hi,
I have a somewhat large Agenda Library, so moving Projects from one Category to another can be quite annoying, because I either have collapse all categories, so I can somewhat easily pull the project into the target one or I have to just pull the project with everything open and hope the scrolling is working (which its usually not or just with a lot of wiggling ). Could you add the option to move a project into another category to the context menu (the one that comes up when you click the three points on a aproject). Upon clicking on the point it should show all available categories and move the project into the choosen category when clicking on it.
Best regards,
Tobi
