Move notes from inbox to project
I may have asked this before, If possible,
Could you creat a keyboard shortcut to move a note to a project. CMD-Crtl-M or CMD-SHFT-M is what other project/note tools use.
I use an inbox religously, and I just want to be able to use a keyboard shortcut to file when I am done. Right now the only solution I can find is drag and drop.
Thanks, Big fan
+1 would love to see this
But then which project would it move to?
I would hope there was a dropdown of all the projects. Here are some images from Evernote and things
Things CMD-SHFT M
Evernote: CMD- CTL- M
Got it, we’ll think about it.
Thank you
I’ve been using the Drafts app as my inbox and would like to forward a draft to a project in Agenda but I can’t seem to see anything in the Share sheet. The Agenda app doesn’t seem to be available in my share sheet.
I use this action in Drafts which copy to Agenda.
Update: in Agenda 14 you can now use the \move command to trigger an Open Quickly like menu to select where to move the note though.
Is it possible to move a line to a different note in a similar way?
ATM you would have to select the line and copy or cut it, then paste.
Depending on your needs Splitting Notes might help: (scroll down to Splitting Notes)
I could also imagine a new agenda function:
Automatic moving of notes from the project Inbox via preset criteria.
e.g.:
Source = Inbox
Destination = Project ?
Intelligent config = contains title, note with #Tag, note with @Person…
So in principle similar to the intelligent folder in the Finder.
Just a quick thought…
That sounds a lot like the overviews Agenda has. It’s not moving the notes, but it is creating a “Smart Folder” which is like an automatic search.
You create them by doing a search for the criteria you want, and then using the buttons at the bottom of the search popover to save it.
