Move folded paragraph without opening it?
On Mac, I use the arrow commands frequently to move paragraphs up and down - as I try to structure my thoughts and my writing.
But when I move a folded paragraph, it moves successfully, but then opens - which is really distracting. I have to then close it and try to find my train of thought agan.
Is there a way to prevent this?
Thanks. It should stay folded after you move it, so that is a bug. We’ll look into it.
We have fixed this now. A folded paragraph stays folded when you move it with the keyboard, and when you drag it. The fix should be in the next update.
