More lag than Agenda v12 on v13
What I did: using iPad smart keyboard doing selection (shift + arrow key)
What happened: lag when moving the cursor between line/words
What I expected: as faster as v12
Things that might be helpful to know (Agenda version, OS and model, etc): iPadOS 14.4.2 / Agenda 13 / Note with Chinese characters, links no pics, attachment.
I recorded it for your reference, click below link:
https://ppt.cc/ficIfx
Thanks for reporting, we’ll go and have a look what could be going on. You only see the lag with shift + arrow key correct? Or also other combinations?
No, only found it when doing shift + arrow key. Furthermore, seem it often happens when the selection include linked text, not sure if it is the situation. Thanks~
Thanks, that’s very helpful, we’ll dive into it.
to update, so interesting, it only be lag on iPad but works fine when using Macbook Pro.
Thanks for the follow up, that’s good to know!
Update: this issue should be fixed in the next Agenda (13.1) update
Thanks, cannot wait for the v13.1!!!
