Inspired by @nickh’s Alfred keyword for opening a note I’ve expanded on the idea little with an Alfred workflow which adds three keywords for things I find useful:
ag [some text] appends [some text] to note ‘Inbox’ in project ‘Inbox’
agp [optional header] appends [optional header] as n H if it’s present then pastes the clipboard contents to ‘Inbox’
Oh - I thought I’d posted this ages ago, & only just discovered it sitting patiently on my phone because I’d not hit Send! Sorry about that - original comment is as follows…
Clicked on the link & got to the site (love the title, btw! 😂), but got an error message saying that the page couldn’t be found. Would you like to check it, please? I’d be very interested to see the workflow 😊
Thanks for reporting, indeed fixed in the final 9.1 update that is now out. One kind request, if you experience issues while being on a beta version, please use the dedicated section in the community to discuss/ask/report as it doesn’t affect the majority of users that only use the public versions.
