Modify Notes when Templates is modified
Hi
I use a template for some Pro notes and I use a templates
Does exist a way when I modify the template (adding tag or person) to amend all notes based on this template ?
Thanks
Patrick
Hi Patrick,
No, a template is used to create a note, but there is no relation to the note after that. It would be very tricky to do this, because you could imagine that changing the template may attempt to change the notes you have made, while the notes themselves are already completely different.
So it is literally a template, ie, a starting point, and after that it has no relation.
Ok
Thanks understood the philosophy behind it
Regards
Patrick
Envoyé de mon iPhone
