Markdown Headlines (# ## ###) sometimes won't work
What I did: Created and edited a Note, pasted some text from Apple Notes or HTML, typed “# Some Headline”
What happened: The “#” disappeared after typing space thereafter. The cursor jumps back to most left position and a tiny bit down. The line is not formatted as H1.
What I expected: The line should be formatted as H1.
Agenda 13
macOS 11.2.3
MacBook Pro M1
No Premium yet, just trying Agenda
Maybe I misunderstood something in the editor or in markup, but this problem appears randomly - maybe after I pasted some text from Apple Notes? I don’t know. In new empty Notes, it works correctly.
Is this a bug or something I mess up?
Thanks for any help!
I’m also experiencing this on my Mac: Premium user, Intel MBP 15, Catalina.
Thanks for reporting this, we’ll have a look. Any further insights, like if it’s indeed related to paste etc would be very helpful.
Ah, I can reproduce it already, we’ll try to fix it ASAP.
Thanks for the quick response. Just to complete this: It appears also on the iPhone.
I believe I’ve just fixed it, should be in a small update soon.
Great job. Thanks!
