Mark As Done
What I did: Marked an item on the agenda as done.
What happened: Marked it as done, automatically removed from agenda.
What I expected: Marked as done and have the item stay on the agenda.
Things that might be helpful to know (Agenda version, OS and model, etc): Did this both from the Menu option and using hot keys. Using Mac OS version 22.
Did you see this?
It is supposed to ask you what you prefer.
I believe it “flashed before my eyes.” I certainly didnt check “Dont ask again”.
Any way to get the choice back?
  • Hold down Option/Alt
  • Click no Agenda menu
  • Click Reset Warnings
