Make note as footnote
Hi
I would like to see, after I make a note as footnote, a behaviour similar when I arquive a project, for example, with Agenda showing all the notes moved to the bottom group together, just to distinguish these notes from all other not move to bottom
Other option could be to format the footnotes with diferent colours and fonts, for example
What do you thing about this?
Best regards, and keep the good work
António
Not that you can mark notes as done, which gives them a different button top-left. Maybe that is a more what you want. The note stays where it is, but has the different appearance.
