Hello TEAM AGENDA
I am an avid user of the #tags in Agenda and I rely on them throughout my work.
It would be GREAT help to have all the tags I saved in the sidebar via “Create Smart Overview from Search” also available in the “Eligible Notes” list in the MacOS Widget (and in the iOS/ipadOS too).
Thanks for taking this into consideration!
So you would like to have an option to setup a widget for a particular overview, so it shows the most important notes from the overview. Is that the idea?
(Note that we can’t show the whole overview, because there is not enough room in the widget, and you can’t scroll there.)
