riven
January 22, 2025, 1:24pm
1
What I did: Nothing (I think!)
What happened: The text of the top note gets overlaid on top of the notebook name. Or sometimes the notebook name text is duplicated and shifted.
What I expected: For the text to display correctly
This happens in Agenda 19 and 20. I think it started after upgrading to MacOS 15 (I’ve just been living with it for a while).
I have seen this too, closing and restarting Agenda fixed it for me. I may have been on an older version though, I got a message about being out of step with my ioS version. I am now upgraded to version 20.0 and not seen it for a while
We are aware that this sometimes happens to some customers, but we aren’t able to make it happen ourselves, which makes it difficult to track down.
If you find a way to trigger this, please let us know.
In the meantime, restarting the app should at least fix it.
I also thought we added a soft return button in the keyboard bar on iPad. You can look in the + menu to see if it is there.
riven
January 23, 2025, 9:07am
4
I’ll keep an eye out and see if I can work out what triggers it.
riven
January 31, 2025, 10:02am
5
I seemed to trigger this today simply by searching for a tag and then clicking “Filter Notes” in the search dialogue. Although then restarting and doing the same thing again didn’t trigger it…
Right. That’s the problem in a nutshell. It is very sensitive to the exact conditions, which makes it very hard to track down.
If you do find something, let us know.
PYC
April 24, 2025, 12:21am
7
Today, while executing the “Search-Project”, after clicking on a project and then clicking “Save Search as Overview”, this issue was triggered.
Useful. Thanks!
I assume you saw overlapping notes from the new overview and the old project, correct?
I see MMM… and Work Lab…
Are they from two different projects/overviews, or the same one?
PYC
April 28, 2025, 5:55am
11
yes,they are from two different projects
