What I did: Made a todo list using checklist format, pinned as “on the Agenda”
What happened: the last items were moved to top. Only for first on the agenda item.
What I expected: the list to remain the same.
OS version, mac has been stable so far
You mean items in the list changed order? Or the notes changed order?
If the list items changed order, that is a bug we are aware of that is quite rare but can arise. We already have a fix, and it will be in our next minor release for macOS.
Hi Drew! Thanks for the quick reply.
Items at the bottom of the list were moved to the top of the note. Typically last two items (occasionally last item) are moved, rest remain the same. This only occurs on the “on the agenda” panel, compared to the fixed similar bug that occurred with every first note on a page.
Corine
Hi Corine,
Can you send us a series of screenshots of what you describe?
I apologize for the delay! Here are the screenshots lined side by side. I hope this clarifies the issue.
Corine
Hi Corine,
Again our sincere apologies for that. This is indeed the bug that Drew has mentioned and that’s fixed in the iOS version already and in the upcoming Mac update (hopefully this week). I’m sorry for the hassle this has caused.
