When I copy a link (from the web), to my notes; eg;
https://sevedbblog.com/ And then I keep typing whatever I need to write; the link doesn’t just stop there, where it should (the space should be enough to define it), but it keeps going and going. Sometimes ever after a couple of returns.
How do I handle that?
I just gave this a try in our beta version on macOS, and it seemed to work. I pasted “https://sevedbblog.com/” and then kept typing. After the space, the link style was gone.
Are you seeing this on macOS or iOS? Do you have the latest version?
