I recently started using Agenda to track several projects that I am working on. There is a lot of great functionality in it inlcuing the linking notes to dates etc.
Many of my notes have links to other notes that i have created. So i create a note and include a link, later i go back to that note and i want to use that link to go back to the reference note. Once i follow the link, is there a way to return to the first note easily, link a back button?
As I get more used to the program I will most likely have addtional questions.
Thanks
Ben
I would like to something like this as well. At least a keyboard shortcut.
We have a browser like history. You will find two arrows at the bottom of the left panel. If you follow a link, clicking the back button there should take you back.
There is the “Go Back” menu item in View that also does this, and has a keyboard shortcut.
Does that help?
Oh my why did I never notice that? Thank you!
Excellent thank you very much. This is very helpful. I am starting to get used to functions. This is an excellent tool. Keep up the excellent work and timely feedback.
