Links are not visible in PDF-Export
Hi,
when I am exporting a note into a PDF Links are not visible anymore. Means theat they are looks like any other text. Not underlined, no other colors.
Additionally it is not a good idea to omit the https or https from a Link in a PDF. Often the text will be copied and then this prefix is missing.
It were nice, if this can be changed.
BR
Thorsten
Thanks for the feedback, noted!
I would love to see this bug fixed. Just underlining links should be sufficient. (I work in accessibility, a color-only distinction does not work for me.)
+1000 on this. I use Agenda extensively, but alas I’m the only one who uses it on my team. I was asked for a PDF of some notes earlier, and was surprised the links weren’t highighted. My workaround was to just share RTF, but PDF would have been preferred.
Yes, this is still an issue. Would love this to be fixed
Good news, this should be fixed in the upcoming Agenda version 13 update. Thanks again for reporting the issue!
