I would like to be able to link one part of my notes to another part of the same note. For example, when I take notes for class I would like to link the sections listed at the beginning of the lecture like this:
1.1 intro to globalization
1.2 what is globalization
To the notes I take later in the lecture. Then I will be able to click the link to jump to specific sections within the same chapter
Thanks for the feedback. We’ll consider it, but we don’t encourage really long notes in Agenda, so not sure this would work that well.
My advice would be to consider splitting the notes into multiple notes. Each section (1, 2) could be a different note. In that case, you can link between them, and they are easier to work with (eg you can collapse one section, move them around, etc)
