What I did: I found I could link to a note with an Agenda Link.
What happened: I couldn’t link to a project or an area in the same way.
What I expected: to be able to do that!
Things that might be helpful to know (Agenda version, OS and model, etc): iOS.
Can we do this? If not, why? Is it planned? Would really help me using Agenda alongside other planning tools to be able to link to projects and areas rather than just spicific notes.
What is it you have in mind when speaking of “linking to a project?” Clicking a link to a note automatically takes you to that note, which is visible as part of a project. Linking to any note in a project will make the whole project visible when you click that link. So unless there was a different result you were expecting, linking to a note and a project are pretty much the same thing.
As for “area,” it’s not clear what’s meant by that…
Linking to a project would essentially open the project at the top rather than going to a specific note. That would be useful if I had some place, like a mindmap, where I’d want to be sure I always ended up linking to the very top of a project, the very latest note added.
Yes, if you type [[ you get your list of projects:
if you then select the project, you get a list of its notes, but the top item is the project itself, if you select that one it will create a link to the project instead of a particular note:
I had exactly this problem! For some reason, perhaps because of the styling of the text, my eye noticed the Project name in the navigation part of the menu (i.e. Sample Projects above) which is un-selectable. Instead of the Project name in the selection area (with the double page icon).
Once I learnt this distinction it works great and I use it all the time!
