What I did: I would like to open an event from the Agenda app.
What happened: It keeps telling me to open it with Busycal (I deleted the app)
What I expected: To open the Calendar app form MacOS
You still seem to have the busy cal app set as the default calendar app, try changing it back to the system Calendar by going to the Preferences in Calendar.app:
I allready looked into that but the default calendar app is the only one showing (deleted the busycal app)
Try the following:
From the calendar app, drag any of your events in there to the desktop, this should create an .ics file.
Select the .ics file in the Finder and choose Get Info from the File Menu or type Command-I.
In the window that appears, select Calendar.app from the “Open with” popup menu, then click the “Change All” button.
Make sure you quit and restart Agenda.
Let me know if that works.
What work was:
I opened the calender app, selected the regular calendar app again as primary app. Agenda notes works fine now.
YMO
July 11, 2018, 6:43am
6
Confirming that this method worked for me.
