If you want to add a link to your bottommost note using the [[
-Shortcut, then the pop-up for searching and selecting a link is not really visible:
the lower part of the screenshot coincides with the bottom edge of my screen.
Indeed a known issue that we’d like to fix (but unfortunately isn’t trivial in our setup).
