Less tap to adjust image appearance
Currently Agenda on iOS requires too many taps to adjust the image appearance. If I want to change the appearance of an image from thumbnail to 50% full width, I have to …
  1. Long press the image to activate the popover
  2. Change the Full Width % from 100% to 50%
  3. Long press the image again to activate the popover
  4. Select Full Width
I would like to skip steps 3 & 4 and wish Agenda can change the appearance to Full Width right after I change the Full Width % option.
I see what you mean and we’ll check if this can be improved. Having said that, Agenda should remember your last setting, so if you configure it once, the following imported images should use the same size, making it a less of an issue perhaps.
