What I did: Type Korean after an unchecked check box then type Korean after a checked check box
What happened: Everything is normal in case of unchecked check box. However, Korean is typed in individual pieces when typing after checked check box. This bug occurs only on iPadOS and not on macOS
What I expected: Typing after a checked check box should behave the same as typing after an unchecked check box
Agenda version: 10.0.4 for iPadOS
iPad model: iPad Pro 11inch 2nd gen with magic keyboard
