What I did: use keyboard shortcut command + shift + x for formatting strikethrough
What happened: it didn’t work
What I expected: the text be marked strikethrough style
Things that might be helpful to know (Agenda version, OS and model, etc): MacBook Air M1, macOS Sonoma 14.5, Agenda 19.0 (302)
screencap for reference https://risu.io/skmQq
trebso
2
Not at my Mac, but I think cmd X is what works for me.
@trebso cmd + x is for cut I think
CMD SHIFT X is working for me. It may depend on the type of keyboard you have. Is it standard English, or something else?
It may also depend on whether you somehow have a global shortcut for that combination. Perhaps try it outside of Agenda and see if it does anything.
For completeness, I just selected some text, and hit that combination, and it worked. Does Format > Strikethrough work as expected?
trebso
5
Of course it is! Back at Mac, and CMD SHIFT X is working for me.
thanks for the reminder, just found it conflict to another app, and it works well after that app be closed.
