Inside a Note
how do i move to note’s title?
Can’t see any KBS for that.
Into a Project
KBS to move a note down/up?
The only KBS i can see is “pin to top”.
Do you mean on the Mac, or iOS?
On both. If i’m not mistaken, i need to use trackpad on macOS & my finger on iOS
On the Mac, you should be able to just arrow up, and it will jump from the top of the text area into the title. Same with down I think.
On the Mac, if you click a note header to select it, you are then able to arrow up and down between notes. There is no “move note up/down” yet though.
The keyboard navigation could be better. We want to work on that.
