I want to be able to use Agenda fully with the keyboard. The one thing I can’t do is link a note to an event with the keyboard. I can’t navigate this popover.
I have a suggestion to add a search box inside the popover and make it active by default so I can:
- cmd + n (new note)
- cmd + shift + d (to assign date)
- type the event name
- hit enter to select event
Also the keyboard shortcuts generally seem a bit unpredictable. Try cycling through your projects on the sidebar and shifting focus from side bar to notes. It doesn’t always work.
We’ll see if we can improve the selection of events in that popover.
If you are editing a note the arrow keys function to move around the cursor and hence using them to move back to the sidebar doesn’t work. Instead try first to hit escape, then left-arrow to move focus back to the sidebar.
