When using the IOS double space to enter a period at the end of a sentence, it doesn’t always work. For example, when I select the last word from the provided list and double space, I do not get a period but a space. This response is consistent. Other apps such as Things work as expected. So I expect Agenda would too. Thanks. Arlington
Thanks for the feedback. Will add it to the list to investigate.
Are you using iOS 12 by any chance?
I am testing this, but it seems to work for me in Agenda just like other apps. Even for the last item in a list.
Can you perhaps send a screen capture video of the issue? It might help me reproduce it.
Using Version 12.4.1
Arlington McRae, Author
The Bible For Beginners And The Rest of Us (BibleThreads.net)
OK, that explains the difference, I think. I tested iOS 13, and that worked. iOS 12 didn’t, so I have changed that. Should work in the next version.
Sounds great. Thank you.
Update: We believe this should be fixed in the upcoming 11.2 update, please let us know if you still see this issue once it’s out.
