If you:
- open a note in a separate window
- set it to be pinned on top
- then minimise that window
…then not only does it seem impossible to bring that window back into focus but it seems to make it difficult / impossible to switch to other apps.
Note: This is only an issue when using Stage Manager.
Agenda 17.0 (269)
MacOS 13.3
Odd, we’ll take a look, thanks for reporting!
I just tested this and can reproduce it, however I am afraid this is a bug in stage manager as, like you say, it doesn’t happen in normal mode. The hard part is that we can’t detect being in stage manager, so it’s not that we can disable it upon minimising only in that case. We’ll file a bug report with Apple.
